Hi!
Usually in my country most of the systems set to 50fps (AC Is 50hz).
And there is no way to set NDI to 50fps (please correct me if I wrong).
Please consider Mach NDI output fps (comp and advanced) to composition settings. or at least let us choose NDI out fps.
Daniel.
NDI output fps.
Re: NDI output fps.
NDI spits out whatever you send it. So if your comp is set to 50fps, and your output your screen via NDI it should be 50fps. Is this not what's happening on your end? The NDI process is on your CPU so you might monitor your CPU's stats while testing to see what your hardware can handle. Here's a video visually explaining what's going on with NDI
- Bassindaniel
Re: NDI output fps.
Actually not.
That’s not the case.
Please see link below
https://youtu.be/rLYgn3nXsM4
NDI studio monitor/vmix/wirecast- all show me 60fps when my comp set to 50.
Re: NDI output fps.
The stream flag is set wrong (we have a ticket for it) but you only get 50Frames.Bassindaniel wrote: Fri Dec 31, 2021 11:39 NDI studio monitor/vmix/wirecast- all show me 60fps when my comp set to 50.
You know, with computer displays and led walls, the display refresh rates are not constrained to the AC frequency any more, like it was with old CRT TV-s
Re: NDI output fps.
Seems to be working great when I send from Arena to Touch. When I change my comp frame rate, NDI follows (See video above). Maybe it's an issue with studio monitor?Zoltán wrote: Fri Dec 31, 2021 13:38The stream flag is set wrong (we have a ticket for it) but you only get 50Frames.Bassindaniel wrote: Fri Dec 31, 2021 11:39 NDI studio monitor/vmix/wirecast- all show me 60fps when my comp set to 50.
- Bassindaniel
Re: NDI output fps.
You know. When I have cameras feed in.
It’s super important.
AC is 50 hz.
Lights are 50 hz.
PWM….
