NDI not working as source on Intel iMac running Monterey
beardyman
Post by beardyman »
oh dear. . . please fix this its making me very VERY sad. . .
Using NDI scan converter, other applications are using NDI 5 just fine. In resolume Avenue, (latest version at time of writing 7.7.1) an NDI scan converter source freezes, reports the wrong pixel ratio, and then just is blank. Weirdly it seems to work when you select some apps to be focused in the scan converter app, but not others, i'm trying to capture a discord screen, this has always worked for me, it is now not working.
Perhaps i should try previous versions of NDI tools? i can't go back from Monterey, apple make that really hard to do. Hope you can have a look at this, it's not fun at all.
dazza
xx
Re: NDI not working as source on Intel iMac running Monterey
Latest version at time of writing is 7.8 ;)
Sounds like macOS is putting your apps to low priority there, so they appear lagging.
Try keeping at least parts of them visible.
VJsynC
Post by VJsynC »
Yup same problem here... in a intel based Mac version NDI capture stop working!!! just blank screen!
Previously it worked just fine!
MacOS version: Mojave
Resolume Version: 7.9
NDI tools version: 5.0
gpvillamil
Post by gpvillamil »
Have you tried this?
In Settings / Security & Privacy / Screen Recording, make sure to add the NDI Scan Converter. Those permissions seem to get reset when you updated MacOS or update NDI.
VJsynC
Post by VJsynC »
Yes... it is active under Security & Privacy / Screen Recording but still... black image
Is Resolume allowed to communicate in the firewall settings?
