Importing Groups from other compositions
djsky
Post by djsky »
Is there a way to import a "Group" into another composition?
Specifically the Laba 4K LightsPatterns uses a "Group" effect to generate the content, but when you import the "Deck" from the composition, it also needs the "Group" in order to generate the desired effect.
Or is it a case of taking a photo and manually creating it in a new composition?
Re: Importing Groups from other compositions
I don't have that comp. If you shoot me a DM with an email and send it over, I can take a look and see what's going on.
