I can copy effect parameters from one clip to another, and all works well *Except* the "Transform" properties....
When I copy the Transform properties, my destination clip ends up with TWO transform effects, one of which (the original) I cannot remove.
Is this a bug that can be sorted? or is there an alternative way of copying the transform properties to another clip?
Copying Parameters from one clip to another...
Re: Copying Parameters from one clip to another...
The default transform can't be removed. To make it not do anything, just load the default preset in it.
Or save a preset in the transform you want to copy and load that preset in the default transform.
