autopilot not working with BPM sync
mowgli
Post by mowgli »
If a generative clip's transport is set to BPM sync, autopilot is not working. When Resolume gets to it, it just stalls on that clip. I've tried with individual actions and with Layer Determined to no avail.
If I switch the clip to timeline sync and then back to BPM they start working as expected. Obviously this is not convenient at all!
Re: autopilot not working with BPM sync
Sources don't have a start and end time so autopilot only works on movie files and image stills.
mowgli
Post by mowgli »
that's not true and it doesn't explain why it works if I switch to timeline and then back to bpm sync...
Which Resolume version are you using?
hmmmm. guess you can autopilot sources. interesting. I'm on 7.8 (Win) and it's working for me. can you update your build?
