Snapshot Via Input Signal
Cassss512
Post by Cassss512 »
Trying to find a way to get to the Snapshot feature via any signal. I've tried converting MIDI to a keystroke (ctrl + Shift + P) via Bome and I can't get it to work. Any other ideas? OSC? There has to be a way to do this. Thanks for the help
Re: Snapshot Via Input Signal
To convert signal to event use an "On Change" node.
I don't think this is about Wire ;)
Try a short recording instead, and use another shortcut to pause the recorded clip.
Cassss512
Post by Cassss512 »
Unfortunately a short recording wont work in this instance, needs to be a snapshot. Originally this wasn't a wire question but his response got me to look into it and I just did a few of the tutorials and its pretty amazing. Now that I'm going that direction any help is appreciated. The input signal can be MIDI or OSC and the output needs to eventually be the Snapshot command.
