Output blinking when window get/lost focus
elgarf
Post by elgarf »
I have problem: my output is blinking, when I clicking on display window or changing parameters like brightness/contrast of display in advanced mode (it makes small additional window with input filed, so focus changed from advanced output window to this input window).
Also if I move display window in windowed mode between displays it span to monitor with same resolution.
I've found, that changing Buffer-flipping mode of resolume profile in NVidia profile inspector to 0x00000001 OGL_FORCE_BLIT_ON solves my problem.
Can it be standard option of resolume profile, or is there another solution?
Re: Output blinking when window get/lost focus
Have you disabled Windows Peak?
elgarf
Post by elgarf »
Arvol wrote: Mon Jan 31, 2022 16:25 Have you disabled Windows Peak?
Yes. It's not fade to transparent, like Windows Peek do. Just one black frame, when I switching between windows.
romano91
Post by romano91 »
Same here, anyone have solution?
Latest GPU drivers?
elgarf
Post by elgarf »
Try to download nvidia profile inspector and set
Buffer-flipping mode of resolume profile to 0x00000001 OGL_FORCE_BLIT_ON.
