Is there a way to automatically switch to the next column when a clip finished playing?
HannesM
Post by HannesM »
Basically the title:
Thanks in advance!
Re: Is there a way to automatically switch to the next column when a clip finished playing?
Check the FB groups for a post by Tom Bass. He made middleware to do that.
Yes, indeed you need some kind of external solution for this.
This one can do it for you too: http://resolume.com/forum/viewtopic.php?f=5&t=11392
