Sync 3 pc with osc
Timoxy
Sync 3 pc with osc
Post by Timoxy »
Hi all,
i need to control 3 resolume with OSC.
I try osc touch. All my computer are find from touch osc. In resolume i find all my computer.
But when i send command, my primary computer find the command but not other computers.
All my computer are on the same network.
So how to connect all my computers on touch osc ?
Thanks in advance.
I use resolume 7.0.5
Re: Sync 3 pc with osc
How about sending to broadcast IP?
Timoxy
Post by Timoxy »
Yes i try to work with this but i don't understand how to set this with other computers.
But i don't find tuto or manual about this.
I don't think we have a tutorial how to set up TouchOSC, maybe you can find it on
https://hexler.net/
With an network IP range of 192.168.1.xxx and netmask of 255.255.255.0 your broadcast address would be 192.168.1.255
Set this as destination IP in TouchOSC, and all the machines on the network will receive the packages.
Set all the Resolume machines to the same port in the OSC preferences, and make sure touchOSC sends to this port.
https://resolume.com/support/en/osc#sen ... o-resolume
