Wire: 7.9.0: Right click to select node to create no longer works (need update docs)
webel
Post by webel »
Not high priority, but I just upgraded from Wire 7.8.0 to Wire 7.9.0 and as far as I can tell the first of these node creation options no longer works (instead there is now a useful different context menu):
https://resolume.com/support/en/wire-user-interface
Nodes can be created in three different ways. The first method is to right click on an empty space and find the node you need. The second method is to double click on an empty space. This opens up a search bar that lets you search for a node. Nodes found this way have a description and an example patch attached to them. The last method is to click on the library tab and either search or scroll to the desired patch, then drag it into the patch.
The 2nd method is more powerful and flexible. In any case, if the first method has been removed the online docs might need to be updated.
Darren Kelly (PLAYlogo), Webel IT Australia
Re: Wire: 7.9.0: Right click to select node to create no longer works (need update docs)
Indeedy, the docs need an update ;)
Thanks for letting us know!
MarkyMark
Post by MarkyMark »
Thanks for noticing, I fixed it. 8-)
