WIRR: Replace node crashes wire in "All" mode
vhsdestroyer
Been using wire for complex text manipulation, the replace node is the most common crash I'm encountering. If hooked up in "all" mode it will instantly crash. "First" and "Last" seem to work fine.
- Attachments
- 1016F639-C672-4ECB-8349-E4FA1171220A.jpeg (66.43 KiB) Viewed 3134 times
Re: WIRR: Replace node crashes wire in "All" mode
If you have a specific patch where it consistently happens, we'd love to check it out!
