Is DVX3 High Quality 10bpc or 16bpc (or other)?
webel
Post by webel »
I'm having trouble finding a definite answer for this.
Q: Is DVX3 High Quality 10bpc or 16bpc (or other)?
The Mediainfo app on Mac gives bpc for most codecs, but not for DXV3 (although it loads it and analyses fine).
Grateful for any other info you can provide on differences between DXV3 High vs Normal.
I appreciation commercial IP may restrict the answer you can give.
Darren Kelly (PLAYlogo), Webel IT Australia
Re: Is DVX3 High Quality 10bpc or 16bpc (or other)?
DXV is not really about bits / color,
You can read more about how DXV works here: http://resolume.com/forum/viewtopic.php?p=62953#p62953
