Telegram message to Resolume Text Block
Hey everyone...just want to gather some ideas from you guys
A friend and I are trying to achieve the following:
We have a Telegram Group with a couple of users in it.
Every time a new message pop's up
"something" has to recognize the new message >
copy it >
and send it via OSC String to the Text-Block into Resolume.
Any ideas? :P
Best wishes
Re: Telegram message to Resolume Text Block
I built this guy as a gift to the industry during 2020's pandemic. I'm sure if Telegram has an API you can connect with, you could do something similar with websockets.
https://pixelparty.gumroad.com/l/twitch ... ixel_party
very nice work! :D what a nice tool....
Not sure if this page helps? Just stumbled across it.
https://core.telegram.org/
We already tried that 😃....sadly it's all outdated. There is a guy who is working on a new compatible version..... but its not ready yet.
Well that's unfortunately. Glad it's still being actively worked on.
ZoltĂĄn
Post by ZoltĂĄn »
Not sure ho telegram supplies stuff, like if there is an RSS feed, but with the new Resolume API, you could use curl to get a website, some bash magic to get the text you want and send that to Resolume clip via curl post again.
nice idea.....will check that out!
ZoltĂĄn wrote: Thu Feb 17, 2022 09:42 .....and send that to Resolume clip via curl post again.
Can you give me an example for the curl post syntax to send a string into a "Textblock" textbox?
Greetings
ZoltĂĄn
Post by ZoltĂĄn »
So, turns out text params are missing from the API, we'll fix that.
Meanwhile using OSC should work then.
Python has an OSC library ;)
