Erro 7.3.2 - program closing
Locked
dvjmusic
Post by dvjmusic »
This version is closing itself when playing a specific video.
To take the doubt I installed previous versions to test, then came the confirmation. This version 7.3.2 is having problems
The same file works without closing the program in versions 7.3.3 to version 7.3.9.
I sent the tests to the official resolume email and sent the log file. I expect an urgent solution. :oops:
To have no doubts, the test was on my computer with other versions of resolume.
Re: Erro 7.3.2 - program closing
Why are you not using the latest build that is 7.9?
Maybe share the video so others can help???
I expect an urgent sent video file. :o
Fixed in 7.3.3 and newer.
Convert your video to DXV, and that will solve it too.
dvjmusic
Post by dvjmusic »
If the version has problems I will not convert more than 8000 files.
The version is in trouble and you know and want to force me to pay for an update and not fix the version.
I want a friendly solution. Because the error is the resolution, not mine.
Forcing the customer who paid dearly to upgrade to solve a problem, is that right?
dvjmusic
Post by dvjmusic »
Arvol wrote: Tue Feb 22, 2022 23:14 Why are you not using the latest build that is 7.9?
I will not pay more for update. Do you think it's right to pay every time to fix errors?
dvjmusic
Post by dvjmusic »
Zoltán wrote: Wed Feb 23, 2022 13:10 Fixed in 7.3.3 and newer.
I paid for version 7.3.2 working, so I want it working. It wasn't for free.
So convert your files to the right codec and your software will work. Would you get made if you put diesel fuel into a gasoline engine and it doesn't work? Loose the attitude or NO ONE in LIFE will help you!
Locked
