Artnet unicast problems at r7.9
Bassindaniel
Post by Bassindaniel »
Hi!
For the past week.
With two different Resolume arena machines.
Two different lighting desks (ma2 and ma3).
I had a few connections issues.
Both solved by sending artnet as unicast (usually I use broadcast).
Firewall is off.
IP settings set to use same network.
No network switch.
Any ideas?
Re: Artnet unicast problems at r7.9
What's the interface IP, console IP, and netmask?
What's the broadcast IP on your network, and does Resolume select that when you use the Broadcast setting?
How are you connecting up two machines and two consoles to a network without a switch?
Bassindaniel
Resolume ip: 2.0.0.98
Console ip: 2.0.0.10
Netmask tested with 255.255.255.0 and 255.0.0.0.
Tested with and without switch
Seems to work fine for me with broadcast too between two computers.
How do you have DNS and gateway set up on the computer?
Win or mac?
<Console>
IP: 2.0.0.1
Subnet: 255.0.0.0
Gateway: <Blank>
Primary DNS: <Blank>
Secondary DNS: <Blank>
<Resolume PC>
IP: 2.0.0.100
Subnet: 255.0.0.0
Gateway: <Blank>
Has worked flawless for me for decades!
No firewalls and routers, just switches and you should be fine.
Bassindaniel
I'v did it many times before.....
Arvol wrote: Tue Mar 08, 2022 17:00 <Console>
IP: 2.0.0.1
Subnet: 255.0.0.0
Gateway: <Blank>
<Resolume PC>
IP: 2.0.0.100
Subnet: 255.0.0.0
Gateway: <Blank>
