Anyone have any experience with various sensors for Resolume?
Specifically, I think I'm looking for a rotary encoder. I want to be able to track video to a moving piece of scenery. So some kind of wheel sensor that will return the position of the piece of scenery, which I can somehow map to X-coordinates of a layer of footage.
Anyone have any ideas for this?
Sensors?
Re: Sensors?
I've done on the fly re-mapping using rs232 and TouchDesigner to send out OSC to change parameter values in Resolume. Maybe look into that? It all depends on what hardware you decide to use.
Re: Sensors?
Well I guess that's my question. I don't know what hardware I should be using...
I see rs232 as a serial protocol, but I'm not sure about what sensor would use it.
Thank you!
Thank you!
- gpvillamil
Re: Sensors?
I can think of many ways to do this.
Not sure there is anything directly off the shelf. You will probably need something like Chataigne or Touch Designer to mediate between the sensor and Resolume.
How accurate does it need to be, and how far will the piece of scenery be travelling?
One approach is homebrew, quick & dirty.
Use an Arduino to read a distance sensor pointed at part of the scenery, send that into Chataigne, and convert it into MIDI or OSC. I've used Sharp IR sensors in the past, they have a long-range variant that could work. https://www.sparkfun.com/products/8958
Another approach is to put a rotary encoder on a wheel, attached to the scenery. Use an Arduino to read the encoder, and send the readings to Chataigne. This might be a good starting point: https://hackaday.com/2018/12/13/every-c ... y-encoder/
There are tons of different ways to do this, but will most likely involve Arduino + Chataigne.
The other approach is to go all fancy, and borrow some tricks from the virtual production folks.
Stick something like a Vive tracker (https://www.vive.com/us/accessory/tracker3/) on your scenery, and use a PC running tracking software to receive the position info. You'll need the base stations as well.
Touch Designer seems to support VR trackers (https://docs.derivative.ca/OpenVR_CHOP), you'd have to do a little bit of patching to turn the received coordinates into something Resolume can use.
There are plenty of projects using Touch Designer to track moving objects, so this could be a good option for you. Might be a lot more precise than the homebrew / Arduino option.
Re: Sensors?
probably is this that you are looking for?
https://www.phidgets.com/?tier=3&catid= ... &prodid=13
and you can do a simple max msp patch to convert the values from the sensor to whatever you want, midi, osc, you name it.
