Resolume 7.3 with Blackmagic HDMI Quad recorder
Heine84
Post by Heine84 »
Hi guys,
I got a Problem. I Hooked up a Notebook into the Quad Recorder an than into resolume. Video is Playing fine But there es no Sound coming into this Clip. In OBS this method works fine, so no trouble with the capture card.
In resolume, the Audio Input device is selcted Too. There is also no „signewave“ in the Transport Window at this Clip.
Cant Resolume handle any Audio Input over BM capture cards?
Re: Resolume 7.3 with Blackmagic HDMI Quad recorder
Are you able to update to the latest build? There's been some BMD work in the past that might fix what you're having issues with,
Heine84
Post by Heine84 »
Update resolume or decklink cards? Cards are on Firmware december 2021
Resolume is on version 7.9 now ;)
Heine84
Post by Heine84 »
Oh cool. Do they fixed this Problem in the newest Version?
I believe so, can you test?
Heine84
Post by Heine84 »
unfortunately Not. Have to buy a new Update. So Thats the question of they solved the problem with the BM cards. Otherwise it does not make sense.
Audio input to clips from capture sources is not supported in Resolume currently.
