Avenue multiple clips on one DMX Channel
milkmgn
Post by milkmgn »
Hey guys,
The company I work for just got an led wall, and i was wanting to automate our slideshow with dmx, with one or two channels, using values to select which slide i want (0-5 slide 1, 6-10 slide 2, 11-15 slide 3 .etc) but it seems that you can only have 1 channel per clip. Does anyone know how to do this or is it not possible? Thanks.
Re: Avenue multiple clips on one DMX Channel
Avenue doesn't support DMX input.
In Arena you can use the Connect Specific Clip shortcuts and trigger 255 clips using only one dmx channel: https://resolume.com/support/en/dmx-sho ... ip-trigger
milkmgn
Post by milkmgn »
Oooooh, thanks, i didn't see that. Will get back to you with any issues that arise.
