bug with CC on R7
VJChemuel
bug with CC on R7
Post by VJChemuel »
Hello there
have some trouble with novation launch control xl connected to Resolume 7.
Controller is connected to the laptop with MIDI in and out activated in preferences.
While assignating a CC on layer opacity, the control change stay blocked on 9/CC78
This same CC is assignated then on other layer opacity and there's no way i can delete it.
When i just open the midi shortcut, if just click on the layer the 9/CC78 is put and can't remove it too (right click remove shortcut don't work too, neither in shortcut panel)
In Shortcuts panel, i can't change manualy the channel or CC (mode is absolute), parameters remain locked on 9 and 78.
even crossfader make a curiously quaking as he's automaticaly assignated to the mentioned CC
should i push the controler in trash or ?
Thanks a lot
edit : i'm running on win10 i7 with a gtx 970m
Re: bug with CC on R7
Sounds like your controller is sending the CC all the time.
If you open up the midi inspector in the midi preferences with the small play button on the top right do you see them coming in?
VJChemuel
Post by VJChemuel »
Hey there,
indeed ! in the panel, there is a continuous message flow.
As you said, looks like the controler is sending messages to resolume
Could be a faulty encoder then, or maybe just how the controller is programmed?
Do you have a utility for it?
VJChemuel
Post by VJChemuel »
The controller is not really programmed, i just plug in with usb and try to midi map.
Top right factory button is red, not much more.
What do you mean by utility ?
with https://components.novationmusic.com/la ... /templates
you should be able to personalize your controller,, maybe there is an option to switch the CC to a note, or disable it.
VJChemuel
Post by VJChemuel »
OK it was rather simple : i went to your link and creat a clean new template and sent it to the launch control.
open resolume : don't work
Reboot
open Resolume : it works !
thanks and have a nice day
