Hi all
i have a question, i am going to do a mapping of a sphere with 4 projectors, so my question is:
how do I edge blend the right side of the 4th projector with the left side of the 1st projector?
Probably this is a numb question but i am not figuring this out.
kind regards
sphere mapping
Online
- Team Resolume
Re: sphere mapping
Re: sphere mapping
Thank you
So from what i understood I just need to put the left and right slices bigger than the end of the canvas, is that it?
Thank you
Thank you
Thank you
Online
- Team Resolume
Re: sphere mapping
Yes, drag it out, and that should go over to the other side.
