I'm finding it very difficult to take advantage of the logic processing in wire. There is pretty much OSC and MIDI to get data out of wire into resolume. I'd like to see the ability to move floats, integers, and bools back and forth.
For example, the ability to read the duration of a clip and the clip timeline position, manipulate that data in wire and write that data to another clip's timeline position on a different layer, with randomness introduced.
Wire: Global Commands
Re: Wire: Global Commands
This is the same as the Global Shortcuts request that was suggested half a year ago.
+1
Having the ability to map one parameter as a shortcut, then be able to reference and apply that shortcut to other parameters within the UI would be a game changer. This is how we can automate our entire setup to play with each other. (then we just need a timeline
+1
