Resolume not saving Wire colour
elbundlo
Post by elbundlo »
Hi there,
Has anyone here been having problems with saving Wire 'colour in' with Wire sources in Resolume?
This is the problem I have: I have made some Wire sources with 'colour in' so I can change colours of them in Resolume, so far so good. I save my progress and update the preview screens in the layers.
However, if I change deck, or close Resolume, I notice that my colour changes are not saved. This does not bode as I do not want to have to go through every wire source in my show every time I start up Resolume.
Look forward to hearing about a solution to this, as I think Wire has a lot of potential.
Cheers,
Paddy
Re: Resolume not saving Wire colour
Seems to work fine for me, which Resolume version are you using?
Do you maybe have more than one color input, and they being named the same?
elbundlo
Post by elbundlo »
Hi Zoltan,
I am using the latest version of Resolume.
Good point about the naming of the colour in, they are all the same name, didn't think about that...
I have been changing the name for colour in in all the wire sources and it is working so far. Thanks!
Great to hear it's working with different names!
We're checking what we can do about same name parameters.
