Wire: Example patches should not replace current work.
Hey there,
I am still learning wire and while working on a patch I sometimes have to look at those nifty shortlinked example patches.
Maybe it's just me, but it feels not so nice that the examples are closing my actual work....and after checking the example I have to reopen my patch.
What about an overlay button in every example called "Back to my work" or so..... So the user can switch back and forth a bit faster?
Best wishes
AngeloDV
Re: Wire: Example patches should not replace current work.
Post by AngeloDV »
I agree, or instead open a new instance of Wires just for examples
We're working on this ;)
webel
Post by webel »
Challenging I know, but a nicer workflow for this would be nice. In some cases it would be sufficient to load a passive image of the tutorial patch. Might not be doable. But often it is not important to see it running, just some typical wiring/patching.
Darren Kelly (PLAYlogo), Webel IT Australia
Zoltán wrote: Mon Mar 21, 2022 18:59 We're working on this ;)
Excellent as always :P
