Mac OS Monterey Extended Display Not Outputting
jotrujil
Post by jotrujil »
Mac OS Monterey Extended Display Not Outputting, I seem to only be getting output via mirrored display. When I use the identify display feature in Resolume, display 1 is the only one that shows up on my laptop screen and nothing is outputting to my secondary display
Re: Mac OS Monterey Extended Display Not Outputting
Do you have Displays have separate spaces enabled in the OSX Mission control settings?
Do you have display mirroring disabled?
lightpainter
Post by lightpainter »
Hi there,
I have the same issues. Only with screen mirroring i have output on composition and preview. When i switch to extended i have no more output on composition and preview.
I use also Mac OS Monterey and Resolume Arena 7.10.0 on the macbook Pro with DisplayLink Manager HDMI output on USB C
I've recently updated Mac OSX, then this problem started :(
Greetz Miguel
Which mac are you using?
liVetoair
Post by liVetoair »
Was there a solution found to this problem?
I am running Monterey on a 2017 Macbook pro with;
  • a 2.3 GHz Dual-Core Intel Core i5 processor;
  • an Intel Iris Plus Graphics 640 1536 MB graphics card;
  • and 8GB of RAM.
I'm having the same problem with Avenue 7 (I'm poor), but even more interestingly, it seems to recognise my main display as both the first and second display when I click "Identify Displays" (picture below)
Mirrored displays is off, I've monkeyed around in the settings as much as I can, but for the life of me, I cannot get it work.
Any insight will be incredibly valuable to me and, no doubt, others in the future.
Thank you!
liVetoair
Post by liVetoair »
Awesome.
Working perfectly now.
Thank you!
