Wire 7.10.0: Perlin Noise instancing ignored (all channels same value)
webel
Post by webel »
Wire 7.10.0: Perlin Noise gives same value on all channels no matter how many instances specified.
Compare with Random (works fine).
Darren Kelly (PLAYlogo), Webel IT Australia
Re: Wire 7.10.0: Perlin Noise instancing ignored (all channels same value)
Yes, perlin noise is an algorithm: https://en.wikipedia.org/wiki/Perlin_no ... ame%20size.
Try instancing the phase offset with different values.
webel
Post by webel »
Thx, 2-instance Random driving phase gives 2 unique Perlin Noise values.
