how do you do that effect where the speed of the clips progresses forward
vj8k3
Post by vj8k3 »
and you can play it on beat. Saw it being used a few times, and then at Tipper even. Its like the VJ can hit a button and the play back of the clip goes forward quickly for a second then seamlessly goes to normal speed until he hits the button again
I can find an example if needed
thanks a lot!
👮♟ ş𝕄𝕆ⓚᗴ ℂяⓐ℃k 卄AιĹ 𝓈ΔⓉ𝒶Ň 😎
Asus pro duo
Intell cor I7
16 gig ram
Gforce rtx 2060
mouse
Re: how do you do that effect where the speed of the clips progresses forward
Map your button to your "selected clips" speed. When the button is pressed move the speed up to something like 2 and when the button is not pressed have it go back to 1
