I'd like to play a clip from the beginning and then loop a later portion so that the beginning doesn't play again. Similar to how loops work in Ableton Live. I can't seem to find a way to do this in the documentation. Possible? Thanks!
-Eric
Play from start, then loop later portion of clip?
Re: Play from start, then loop later portion of clip?
Yes it is possible.
- Place two copys of the same clip side by side in your clipdeck.
- Edit the startpoint of the second clip to what you think is right.
- Set the playmode of the second clip to "loop"
- Set the Autopilot of the first clip to "play next clip"
>> Trigger the first clip and wait for it = voilá
Best wishes
Best wishes
Do you like outlines? Easy Outliner on Juicebar
