Colorize not outputting on all slices...
Bassindaniel
Post by Bassindaniel »
Hi all.
Having a strange issue with r 7.10.
I have a project with a 1920x2160 comp.
This comp is divided to 4 projectors via advanced screen. 3 hdmi outs and one sdi.
One projector facing the back wall
Two protectors facing to the floor.
And one to a text strip.
Yesterday, I did programmed my show all day long.
In some point I noticed that the projection on the floor (2 projectors. Same model. Both connected via hdmi) is not effected by colorize as it should be.
One of the projector did get the colorize color and the other one no.
One file. One colorize effect on file.
Can see colorize effect only in one out.
Now. The weirdest this is this:
On my UI monitor I can see it correct.
Test card look good on stage.
It’s looks like only colorize FX is ignoring some slices on advanced screen.
Hope that’s was enough info.
any ideas?
Daniel.
Re: Colorize not outputting on all slices...
Is the colorize effect on the clip or the composition?
Is the layer routed to the slice for the projector which didn't get it applied?
https://resolume.com/support/en/slice-routing
