Juicebar stuff messed up with 7.11
introvertmusic
Post by introvertmusic »
I'm a non M1 user and 7.11 messed all of my Juicebar stuff up.
I deleted literally everything, unregistered everything loved out of everything (Juicebar and Resolume) back dated my Reolume but now the Juicebar logo shows on stuff... STILL!
I played a HUGE show last night and totally threw up a Juicebar logo several times... 7.11 made me feel stupid. VERY NOT COOL
I would tell everyone not to upgrade to 7.11 - creates errors that are very much not fixable at this time
Re: Juicebar stuff messed up with 7.11
introvertmusic wrote: Sun Apr 24, 2022 04:44 back dated my Reolume but now the Juicebar logo shows on stuff... STILL!
JuiceBar logo shows up when you're not logged in to Juicebar on the machine.
If you see the same in 7.11, and 7.9 it's probably not related to the 7.11 update.
Could you please send us the Resolume log file via the feedback tab in preferences?
dirtyjohn_lv
Re: 7.11 is non-starter on m1
Post by dirtyjohn_lv »
I've had an issue with JuiceBar plugin Shape Chaos Magic (Wire patch).
Worked fine before Silicon update. Now shows JuiceBar watermark when trying to use patch. Using Rosetta vs Silicon doesn't matter.
Same plugin on windows doesn't work with 7.11 anymore, shows JuiceBar watermark.
Other plugins from JuiceBar are working fine on both systems for me, just the one that involved wire
Can you also send a screenshot of the watermark you see?
dirtyjohn_lv
Sent
Thanks Evan,
​I seem to have some watermarking issues with regular FFGL plugins too.
​We're in touch with Juicebar to resolve these.
​For the Wire patches, I'd recommend keeping Resolume 7.10 for now.
