Drag-n-drop not work
Bert_Jickty
Post by Bert_Jickty »
We can't drag-n-drop any mediafile from explorer now. But from "Files" i's inserting ok.
Win11, Arena 7.11.2 rev13714
Re: Drag-n-drop not work
Are you running Explorer and Arena with the same user?
(ie, Arena not "run As admin")
Bert_Jickty
Zoltán wrote: Mon Apr 25, 2022 10:08 Are you running Explorer and Arena with the same user?
Arena running as Admin
The User context needs to be the same privilege level for the apps, otherwise they won't be able to share data. So you could either run both as Admin, or run them as your regular user.
Bert_Jickty
It worked fine last week. What happened over the weekend? On three computers
Are you starting Resolume with double click on the program icon, or right click, Run As Admin?
Bert_Jickty
There is a checkbox to run always as administrator. Because it's software version, not dongle. And registration verifies only if run as admin.
Bert_Jickty
Aah! I'v tried to uncheck the "Run always as admin" ckeckbox and it's worked. And how I can run as admin and drag-n-drop? I must run as admin for verifying registration, but not drag-n-drop. Or drag-n-drop and run as admin in once a month? It's not convenient.
In windows I work on the local admin account.
Windows 11Pro v.21H2 b.22000.613
Bert_Jickty wrote: Tue Apr 26, 2022 03:41 Because it's software version, not dongle. And registration verifies only if run as admin.
This permission issue should be fixed in 7.11, so hopefully you don't need to run as admin any more to keep the registration up to date ;)
Bert_Jickty
OK! It would be great!
