Media manager failure Mac to pc. version 6
kobiwan
Post by kobiwan »
Is it a known issue for Resolume 6.1.5 that compositions made on a mac, collected with media manager does not work when transporting to a windows machine??
my collaborators report that media manager on the windows machine just hangs for ever and can not even list a single of the missing clips? Apparently it is a known issue according to some…
Any help or workarounds?
Re: Media manager failure Mac to pc. version 6
Collected Compositions, open up with all the media in place, they use relative paths inside.
Are you sure you're using the collect, and copy the whole bundle to the other machine, and not the original composition and files separately?
kobiwan
Post by kobiwan »
thanks for the reply Zoltan!
I think that might have solved it…
