OSC control via name instead of number
benwillcox
Post by benwillcox »
Hi all, I'm a new Resolume user and have searched for an answer to my question but can't find a solution.
I am using Arena to playout various individual clips over different layers, using OSC which is controlled by an automation script I have written.
Each clip is addressed by layer and column e.g. /composition/layers/3/clips/4/connect but this means that any modification such as adding new layers and columns breaks the functionality as my script then addresses the wrong clips.
As I have named my layers, clips and columns I was hoping that there was a way to reference these in the OSC commands, so that I am addressing an absolute clip rather than a layer/clip index. That way it doesn't matter if I insert columns or layers, my automation would still work.
Is this possible, and if not could it be considered for the future?
Thanks,
Ben
Re: OSC control via name instead of number
Indeed this is not possible currently. At least not directly. You can poll the clip names fot he layer/column positions, and if you can process those, then you could program an interface you can use to trigger clips by name.
We have a ticket for this.
benwillcox
Many thanks for the reply,
Ben
