Audio cutting off at 2:47 during live recording
fetzav
Post by fetzav »
Greetings friends! First time poster. I'm having a very frustrating experience and I need some help. I am recording a music video in Resolume. I have an audio track loaded into layer 1. I hit record, trigger the audio, then I do my visual performance, I end the recording. Every singe time the audio is cut off at 2:47. All of the visuals I performed are there, but compacted into the 2:47 time frame.
I have gone over this 2:47 limit before, I just don't know how I managed it. I know Resolume caps out around 35 minutes of audio during a recording, so this makes no sense to me.
The song I am making the video for is 4:33 - not very long.
Stats:
Windows 10 16gb ram
Resolume Avenue 7.70 rev9779
I am using a very fast external SSD to run my content, and to record to
Thanks for your help,
Fetz
Re: Audio cutting off at 2:47 during live recording
The 35 min cap was an issue we fixed in 7.3.2
Which format are you recording to?
How much free space do you have on the target drive?
fetzav
Post by fetzav »
Thanks for your reply. I am recording to Motion JPEG. I have recorded over 75 minutes before of Motion JPEG on accident (hit the record button during a live show and didn't realize).
Target drive is an external SSD and has 899 GB of free space.
It seems that Resolume is compressing the video by about 70%. Not sure if there is some speed or compression control. The master clip speed control is set to default.
When I recorded audio only, I was able to capture the entire 4:33 song. I recorded video without audio and my video was still getting cut off.
I just ran a test. I recorded video only for 1 minute. The final clip was 0 minutes 44 seconds. Quite perplexed as to what is going on.
Which gpu are you using in your machine?
What does the fps say in the preview monitor when you're recording?
