Having trouble using Ableton to sync visuals with Resolume using SMPTE
TwoPackShaker
Post by TwoPackShaker »
Hey all, I watched Julian Gray's video (https://youtu.be/eoIqlcAGjEw) on syncing visuals in resolume with smpte in ableton and I'm having trouble getting it to work. Basically the visuals are just not synced. Anyways, I made a video (https://youtu.be/SYwY34yJ6_M) explaining my situation more.
Any help would be appreciated, thanks
Re: Having trouble using Ableton to sync visuals with Resolume using SMPTE
It seems the audio input device is greyed out there in the Resolume preferences, which could indicate that there is an issue opening it.
If you don't need frame level sync, try Ableton link and BPM synced clips in Resolume, that should get you pretty close too. https://resolume.com/support/en/search/ableton%20link
