Is it possible to render a clip so that it takes the properties of your slice in Advanced Output?
For example, I have a 4k clip, but I really just want to cut out a 756x432 section of that clip and have that as a stand alone clip... Is that possible to do with record or render?
Render to Advanced Output
Re: Render to Advanced Output
Method #1:
Add your current comp layer setup to a MASTER group, then go to advanced output and assign your slice inputs from Composition to the MASTER group. Then, create a new screen in advanced output and select the slice input to be the first screen in advanced output, Then assign the second screen's output to Spout.
Then create a new layer above your MASTER group and import the screen 2 slice source and play that and then hit record.
Method 2:
Don't add the new layer from above^ but instead open OBS and bring in the spout source that way and record.
Method 2:
- Bassindaniel
Usually I record my advanced output through NDI output and recording it via Vmix / Wirecast / NDI studio monitor.
