Would be great if you could assign these buttons to a shortcut
Assign Deck scroll buttons
Came across an issue that you can't assign the buttons that scroll through decks that have been loaded (see attached).
- Attachments
- deckscrollbuttons.jpg (27.97 KiB) Viewed 15633 times
Re: Assign Deck scroll buttons
Hey there.... you may also post your version number for the staff
Are they also not mappable when you use one of the standard window layouts? because, normally...it is possible
Do you like outlines? Easy Outliner on Juicebar Re: Assign Deck scroll buttons
Are you looking for this?
Hey Zoltan
Thanks for the reply, I mean the buttons (far right default interface) that move/scroll along the deck names if you have quite a few loaded not the ones on the left that load the next/previous deck. The ones I mean currently are not coloured when in shortcut edit mode and if you click on them you cant assign anything to them they just scroll the deck names.
v7.12.0cosmowe wrote: Thu Jun 09, 2022 10:26 Hey there.... you may also post your version number for the staff
Are they also not mappable when you use one of the standard window layouts? because, normally...it is possible![]()
Yep in the default interface it is not assignable and it doesn't go coloured when in the assign mode.
hmm, yeah, these can't be mapped currently.
I prefer to use the Comp browser and just double click the deck I want this way. A list view is easier to navigate anyways
I do use the comp browser that way because of the search but if you forget to save a deck and reload it that way you lose any changes you made :'(Arvol wrote: Thu Jun 09, 2022 16:05
I prefer to use the Comp browser and just double click the deck I want this way. A list view is easier to navigate anyways![]()
ah cool good to know hopefully it will be assignable at some point in the future
Sorry, I also thought you meant the deck switch buttons.VJzoo wrote: Thu Jun 09, 2022 14:45 I mean the buttons (far right default interface) that move/scroll along the deck names if you have quite a few loaded ...
