Resolume Wire
Eddie Coro
Resolume Wire
Post by Eddie Coro »
Hello Resolumers,
I started playing with wire & its fun!
I am thinking about creating advanced plugins for sharing/selling.
One question about compatibility:
If I create a patch and compile using Wire 7.10 should the end user have minimum Arena/Avenue 7.10 as well?
Another example: If I create a patch using Wire 7.12 and the end user have resolume 7.5 will it work?
Re: Resolume Wire
Eddie Coro wrote: Fri Jun 10, 2022 15:49 If I create a patch and compile using Wire 7.10 should the end user have minimum Arena/Avenue 7.10 as well?
Yes.
Another example: If I create a patch using Wire 7.12 and the end user have Resolume 7.5 will it work?
Probably not.
The first Wire release was 7.4, if you want maximum compatibility, you can get that version from the bottom of our download page, and create the patches with that.
Eddie Coro
Re: Resolume Wire
OK Thanks for the answer,
I guess this makes things a bit complicated and from a seller point of view I think i'll hold on.
Re: Resolume Wire
Your Wire license will work with all previous versions, so if you create your patches with 7.4, that should work for everyone.
