Slice effects missing in Avenue
GroovinDJ
Post by GroovinDJ »
Where's the Slice Delay effect? I can't find it...
Might as well join the team
Re: Resolume 7.12 | Pioneer DJ Sync, CrossFader Phase, 3 New Effects, Auto-Layout for Nodes
Right above Slice Transform under Effects.
GroovinDJ
Post by GroovinDJ »
Nope, I don't even have that. Searching for 'slice' brings up nothing.
Under FX? Are you using ARENA version 7 and not 6? Slice Transform has been a staple in VJing for years now.
GroovinDJ
Post by GroovinDJ »
Arvol wrote: Tue Jun 07, 2022 23:59 Are you using ARENA version 7 and not 6?
No I'm not using 6! What thread am I commenting in? I'm asking about the new FX added in 7.12
I'm using Avenue, but the statement above says the 3 new FX are in both versions...
[edit] I just checked the manual. Slice Transform is Arena only - so is the above statement (about 3 new FX in Arena and Avenue) wrong? Do we only have TWO new ones in Avenue - no Slice Delay?
Yeah, If you're using Avenue, anything "Slice" Related won't apply. That makes sense now.
