Improve More power FPS with the EGPU setup
skanpro
Post by skanpro »
Hello, i have a setup with macbook pro 2016 tb and a Egpu with rx6800, i want to use all the power of the egpu but only have 10-15 fps (1920x1080).
for some reason the Resolume arena dont use all the power of the egpu and force more the cpu.
i have all my clips on DXV3 (to use more GPU) and free de CPU as posible.
Re: Improve More power FPS with the EGPU setup
Sounds like a driver issue. Not that I would EVER recommend anyone using a eGPU for a concert setup, But I have had a few people come through with them and they are getting normal fps using them, so I think the issue is with your setup and not a global issue.
Make sure to only use the EGPU display outputs for display connections and also Resolume UI.
