Quick switch in wire
Babcom
Post by Babcom »
Maybe there is a way already, but id love to have a way to quickly switch to try different shapes, effects or so in wire. Lets say use a command + arrow up or down while having a shape selected to flip to a different shape. Or same thing when I have a video effect selected.
All the best. Babcom
Re: Quick switch in wire
Gate node could help with this
Babcom
Post by Babcom »
Yes that sound like a work around, but I'd rather have a built in keyboard shortcut to tinker with the nodes quicker : D
This is implemented in Magic Music Visuals for example, and I love how quickly I can run trough different ISF to see how they work with my composition...
ISF nodes have a dropdown where you can select which shader they should use:
Képernyőfotó 2022-06-30 - 15.41.55.png (61.25 KiB) Viewed 3671 times
