Resolume 7.13 | Clip Time Remaining, SMPTE Panel, Slice Fader & Scaling, Auto Node Layout Improvements
Clip Time Remaining Panel
One of the most requested features on the forum is to show the clip time remaining much bigger in the interface. So we have created a dedicated panel for the clip time remaining where you can decide what playing clips to see the time of and you can show the current system time. You can make this panel very big and the text will scale along with it so that the entire FOH can read it from a distance đź‘€. This is super handy for tightly scripted shows where everybody needs to get their timing right.
SMPTE Input Panel
The SMPTE inputs on the toolbar in Arena were a bit small and not very readable from a distance. We have now moved the SMPTE inputs from the toolbar to a panel so you can make it a big as you like, just like the clip time panel.
Slice Fader
You can now fade the opacity of each slice individually in the Slice Transform effect. Map the slice opacity to your MIDI controller or even animate it to the beat.
Slice Scaling
In the Slice Transform effect you can now also set a different scaling for each slice, so you're not limited to Fit, Fill, Stretch or Mask for all your slices anymore. There is also a new Inverted Mask mode to actually show the pixels outside a slice and not inside.
Multiple Wire Slice Inputs
You can now create multiple slice inputs for your Wire patches. This is nice for creating more complex Wire slice effects like applying different effects to groups of slices.
- + buttons on all parameters
Making small adjustments to any parameter is now much quicker because every parameter has - + buttons next to the slider. Handy!
Shift Click to Fold/Unfold All
Hold down Shift on your keyboard and then click on the fold arrow of an effect and it will fold (or unfold) all effects below it. This also works on the folding arrow for slices in the Slice Transform effect.
The auto node layout feature that we introduced in beta in the previous version is now improved further and out of beta. This has become an essential tool for us to maintain our sanity in bigger patches.
Find Node
With the Find node you can find the position of the first or last occurrence of a substring in a string. Finding a needle in a haystack is actually very easy now.
Resolume 7.13.1 Fix List
#17894 Slice transform should update after Composition size change
#17914 Slice transform in masking mode ignores slice position and mask size
#17900 Many faders are not highlighted and don't show their shortcut in shortcuts mapping mode
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update, including Wire. Or checkout the downloads page.
Re: Resolume 7.13 | Clip Time Remaining, SMPTE Panel, Slice Fader & Scaling, Auto Node Layout Improvements
Thank you so much for these new Features!!! :) Awesome Update
Zenithik
Post by Zenithik »
This is awesome Bart, thank you to you and your team! Is there any way we could get the same click functionality you have to switch time modes on the clip time, except on the system time to change between 12hr and 24hr?
Jayson
Jayson Esguerra
Seattle, WA
Currently working with G Jones & Deathpact
AcdNrg
Post by AcdNrg »
I may have looked in the wrong places, but it might be a nice idea to have a detailed release notes document next to the download links. Or have them zipped into a download package.
Just a simple .txt/.pdf so one can see what has changed, what is new, which bugs were fixed etc.
What do you think?
MarkyMark
Post by MarkyMark »
Good point AcdNrg, we always do that, but I think we've forgotten to do that with this one.
7.13 is mostly about new features listed above. Those are the release notes ;)
