Couldn't seem to find any info on this or find an option in the preferences, so I assume it isn't an option but figured I'd check in case I missed something.
Is there a way to set the tap tempo to generate a whole number like say 156bpm, instead 156.47bpm? So basically rounding up or down to the closest whole number.
Just finding it a bit tedious to tap in the tempo and then have to jump on the keyboard to remove the ".47", ya know.
I'm currently working on setting up a single midi controller to control multiple softwares at once, with some options (like tap tempo) being linked to the same button on the midi controller. Trying to keep my hands and eyes off of the keyboard and mouse as much as I can
Hope I missed something and there is an option for this. If not then i hope there's a ticket for it
Thanks in advances!
