With the start of Pro Dj link its cool that the clips gets triggered when the track is loaded, they start when the track starts.
BUT
What if you have content that only has the verse, chorus or hook in it?
Extra playmode option: 'Free Run' / 'Freestyle' or just 'timeline'
So there is no timecode/track controlling the clip, it just runs as a timeline would do. So than you can retrigger the clip whenever you want. (In pioneer pro dj link you cant retrigger clips because it runs with the track loaded).
Or the option to only use load clip on load track
*I know you can fix this with showkontrol triggering the clips at cue points via OSC to resolume but with 250+ lyrics clips it would take a lot of time.
Pro DJ LINK playmode: Free run or 'load on track only'
boris.lema
OnlineZoltán
- Team Resolume
Re: Pro DJ LINK playmode: Free run or 'load on track only'
Use the offset to start the clip when the chorus starts, make more copies of the clip for if there are multiple chorus parts.
