Control on text animator
Snoxxx
Post by Snoxxx »
Hello,
I use a text animator for multiple timer, exemple 20min (1200line, 1200sec) and i do extenal trigger pause / play during timer.
I test midi or dmx, 2 button for selected + pause clip and selected + play clip, it's ok but if i press "pause" "pause" = "reset clip" and "play" + "play" = "reset clip". Any chance to desactivate double press ? for spam pause = pause and spam play if play do nothing ?
I try to pause with piano mode and it's ok but i do select this clip with another triggered button, I can't select + piano mode (and i'm block when he press pause, if i send other layer, he lost selected, timer don't play on release and when press, Boom 2 times pause = reset ^^)
Can i turn off the auto selected clip (small under), when clip is play with clic ? (remoted it's ok)
I'm going in the wrong direction?
Re: Control on text animator
Double click "play" is a feature for parameters, it's not possible do change the behavior currently.
How do you have parameter animation start settings set up?
