wire - "Show in explorer" don't work with öäü in filename
Hey there,
might found a little bug.
If you save your new wire patch with a filename like this "Zoltan_Lösung", the function:
...does not work.
Best wishes
cosmwoe
Re: wire - "Show in explorer" don't work with öäü in filename
Ah, in Wire, indeed it's not opening up properly.
I'll make a ticket ;)
Thanks for letting us know!
