Hi!
As simple as that:
BG layer is a camera input.
Upper layer clip is a Saturation FX.
(in FX saturation set to 0,
layer blend mode is ALPHA,
layer is at 100% opacity)
When I'm setting the BG layer fader under 100% some colors leaks to competition output.
SERVER HARDWARE:
Resolume arena 7.13.1
Windows 11 pro
intel i9 12900H, 3080ti, 64gb ddr5
Any ideas please?
Daniel.
Saturation behavior
Re: Saturation behavior
Set your FX layer to the Cut blend mode
- Bassindaniel
Ok. That works but.... WTF?
I'm using it for years with Alpha mode.
What happens if i want a layer for a few different FXs and want to control it by fader?
CUT is not my solution...
Then disable the alpha channel on your video router/fx and use whatever blend mode you likeBassindaniel wrote: Fri Sep 09, 2022 21:08 Ok. That works but.... WTF?
When you fade out a layer, it gets transparent, so the effect above it will process a transparent image which will be transparent too. Mixing two semi transparent images, you'll se both in the result.
- Bassindaniel
Can’t thank you enoughArvol wrote: Fri Sep 09, 2022 21:35Then disable the alpha channel on your video router/fx and use whatever blend mode you likeBassindaniel wrote: Fri Sep 09, 2022 21:08 Ok. That works but.... WTF?
