Resolume Not changing faders from the Pioneer connection
alexandremix
Post by alexandremix »
The pionneer is detected, But the faders (the pink vertical fader) never changes, even if the DJ is moving the faders on the pioneer.
I dont know why.
Everything is working except this
Running Resolume 7.13.1
Re: Resolume Not changing faders from the Pioneer connection
Firewalls off, and same network interface set in both Resolume and the Bridge app?
https://resolume.com/support/en/sync-to ... dj-players
alexandremix
Zoltán wrote: Wed Sep 21, 2022 15:44 Firewalls off, and same network interface set in both Resolume and the Bridge app?
firewall on windows is off,
Everything works ,except this fader
Thanks, that looks good.
Do you have other network devices enabled on the machine?
Any virtual TAP adapters by any chance, like the ones used for vpn?
Does setting the Bridge app Mode to Master help?
alexandremix
Zoltán wrote: Mon Sep 26, 2022 17:17 Thanks, that looks good.
Windows only has 1 network adapter. nothing more. this is a fresh windows install , only has resolume chrome and nothing more. How do i put the app to master? Theres server, client and auto options .
nothing called master.
Also the pro dj link is extremely slow when switching any buttons.
Server is master.
alexandremix
Still not working I played around with all options in the app. and also the pro dj link bridge App is extremely slow. Everytime i try to close it does nothing and stops responding
alexandremix
I would really love to make this work.
And im sad the bpm does not sync automatically with pionneer as well even if i click link
as it seems its a info that pioneer bridge app does not share
alexandremix wrote: Sun Oct 23, 2022 01:12 also the pro dj link bridge App is extremely slow. Everytime i try to close it does nothing and stops responding
Are you on windows 11?
The Bridge app can't do Ableton Link.
If you have a mixer which can output Midi clock, that might work to have BPM synced.
