a quick way to find dxv in windows?
Acidvideo
Post by Acidvideo »
I have a folder with over 2000 movs in it. Does anyone know a super quick way to see if they are all dxv?
elgarf
Re: a quick way to find dxv in windows?
Post by elgarf »
XYPlorer can show video compression codec, but it's just GUID.
Add new column -> Select Property -> Video compresssion.
Alley also shows the codec when you load the file.
Acidvideo
Post by Acidvideo »
Zoltán wrote: Tue Sep 20, 2022 11:32 Alley also shows the codec when you load the file.
i know but when i want to check a folder with 1500 movs this doesn't work
