Longer transitions vith OSC /Chataigne ?
ssami
Post by ssami »
Hi!
Can someone help me to do longer transitions in Resolume with OSC?
I would like to use Chataigne for that.
I am making 500 pics autopilot randomized "slideshow" with 8 layers, and i need about 30sec long transition between pictures, on each layers.
I found Chataigne for that and i really need little help from someone who is more familiar with OSC programming.
S
Re: Longer transitions vith OSC /Chataigne ?
Well, if you place your clips into two layers, you can use the layer faders to fade the clips in and out.
ssami
Post by ssami »
Thanks for your answering Zoltán!
So, is it possible to automate those layer faders with OSC?
Show must be run in autopilot and randomized.
max. 10s transition duration value is not enough for us, and this has been problem for weeks now, and i still trying to solve it.
Thanks.
S
For now, you'd need to do the logic for this in a third party app.
We have a features ticket for transition times more than 10 seconds.
