Does Prores to DXV increase performance
puzekatt1
Post by puzekatt1 »
Noobie question here:
I read and understand that dxv is the preferred codec. But it also says that prores is played back in a similar manner. Say I have a lot of prores files, is it worth it converting them all to dxv for a show if I have the time?
Thanks <3
Online
Re: Does Prores to DXV increase performance
If you only need to play a few layers, and the performance is good enough, I'd keep the files prores.
DXV is GPU decode, prores is CPU.
puzekatt1
Post by puzekatt1 »
ManDerLa
Post by ManDerLa »
How about MacBook Pro M1 or higher? What is better DXV or Prores?
